Square bore or Spread bore?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
check my reply in your other post...you should get some answers there.
the spread bore will work with both...the square bore will work with the stock one fine, or the 454/holley one with modifications.
-brian
-brian
Car: 1991 Camaro RS
no.
the square bore intakes are usually for higher performance engines. like, if you look at all of the single plane intakes, etc. they will all have square bore mounting areas.
-brian
-brian
roysatikas
09-22-2015 08:15 PM
