Has anyone tried the 252H Comp cam
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The 252H is a single pattern, 206*@.050, 110* lobe sep. It isn't reccomended, but then there are a few cams being used successfully out there that aren't reccomended. I have one already so it's one less thing to buy for my rebuild.
The only problem I can see is that the LSA is kinda low for a MAP sensor FI system. Maybe if you got a custom chip for the cam you might be ok. Only way to know how it will work out is to try it
Car: '85 IROC
Engine: LB9
I called up Howell this morn and they told me the same thing.
I'll probly need a chip anyhow as there will be other mods.
Thanks for the reply.
