350TBI intake/tbi unit on an L03
I've come across what the seller claims to be a 'ported 350 TBI unit and intake manifold'. I say 'claims', since he also says he got it out of an IROC camaro (year unlisted), and IIRC anything involving a 350TBI and a F-body isn't a stock (much less common) configuration. The price is low, so:
Understanding (from what I've read here) that the intake, heads, cam, and exhaust on the L03 are what bog it down, is there any difference between the stock L03 manifold/tbi unit and this item? Will it fit? Is it worth the time (the price will end up quite low...)??
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I might be wrong, but a 305 and 350 intake manifold are identical. A ported TBI unit sounds just like one with the free TBI mods done to it.
The only plus I see is that you will get bigger injectors, but with a stock chip and engine you will have too much fuel.
Who manufactured the TBI unit and manifold?
And how much is he selling it for?
Post this info and someone should let you know if its worth it.
More info
It's (from his discription) GM stock parts. He says he 'ported and polished' the intake manifold, and that the whole thing was from a 350TBI. Now since I could probably manage to port/polish my 305 manifold, I was just wondering if GM used any significantly better design on any of the items in this part of the larger TBI motor...
It's going for $9.99 right now (but as an auction item with 3-4 days left, it'll probably jump up significantly), and I was considering buying it if it doesn't top $25 or so...
1. there was never a 350 TBI IROC. If the intake that was on the iroc was also used on 350 TBI trucks, that's a different story.
2. Intake swaps are a pain so I'd only get it if it is bored for a 2" bore TBI like the holley 670 or 454 TBI unit. Or if its cheap enough you could get it for $10 and then have it bored for the bigger TBI.
intakes arent that bad. took me 3 hours to do mine. First time i did it. had to stop that damn oil leak. didnt even leak (knock on wood) plan on sticking a edelbrock intake on soon. i have the money but i keep buying stupid crap instead.
1 Post
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
I read on another thread (don't remember were, but is was a TBI thread) that IROCS never came with TBI ever.
yes i am positive it came off of a 5.7 350 the motor was originally a
tpi setup but it was converted to tbi thanks
Decided not to get it
After further research, I have other things I need to get (POR-15 and a wire-brush for my grinder, to start)... Also, based on what I've been reading, it's a good idea to do heads, cam and intake all at once (since to do either of the first, you have to pull the intake anyway), and since if I do a head swap, I'll probably use vortecs (especially if I can get a set from a scrapped truck) that intake won't work...
P.S. What vehicles came with vortec heads, and what casting number is 'preferred' for a L03 head swap?
Car: 1991 Camaro RS
Engine: L03 305 TBI, nearly stock
Transmission: 700R4, stock
Axle/Gears: 3.23 out of a V6/5 speed car.
Hi, new gut here,
I read this post and came up with a question...
Has anyone ever tried a 2" TBI unit off a 454 and put the 305 injectors in it. It seems like cheap extra airflow to me.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Re: Decided not to get it
