Throttle Body Spacers...Fact or Fiction?
Car: 2002 Z28
wait until you have alot of mods before doing the small things, especially when the small things cost around 50 bucks.
Car: 1991 Firebird
Engine: 383 stroker
no...i felt absolutely no difference
Tom
Car: 91 Red Sled
A spacer = more plenum volume (more air/fuel for engine to draw from) and in most cases is a good idea. It all comes down to what your engine needs. A large plenum on a small engine will require less throttle body size than if the engine had a small plenum. It's much more complicated than that but if anything, MAKE the spacer yourself. Save the $$ for something more drastic. A high temp plastic is usually the best spacers because they don't absorb heat like metal (ever heard of a plastic heat sink ) and they are the easiest to machine. Just make sure to test the plastic with gasoline before installing it on the motor.
I had to put one on my rebuilt engine so that the non drop air cleaner would clear the coil and the map sensor.. I don't know if it made a difference since I had never had a chance to try without..
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
