anyone know what size cam this is?
ok i found an LT4 cam out of a 96 vette motor on ebay,and the part number is 12551142.i searched the boards and couldnt find anything that gives the part numbers.i have a spec chart that says that theres 2 size 93-96 LT1/LT4 sizes,along with a Y body LT4.thats the vette right?the y body cam is slightly smaller,so i probably wont go for that if thats the case.thanks for any help!
here you go:
12551142 Hydraulic Roller (LT4 Production Cam)
This is an LT4 production cam 1996. The duration at .050" tappet lift (intake/exhaust) is 203/210; and maximum lift with 1.6 rocker ratio (intake/exhaust) is 476/480. Valve lash is zero/zero and lobe centerline is 115 degrees.
gmpartsdirect has them for 150.00 new
thanks a bunch man.does anyone know the site that has the part numbers on it?i know it exists i just cant find it .i'd like to bookmark it so i can have it for future reference if needed.
This should help. Click on the SB V8 link and have fun!!
http://www.gmpartsdirect.com/perform...s/frameset.cfm
toronto formula
11-10-2015 06:17 AM
gixxer92
09-01-2015 04:32 PM
knight72
08-10-2015 09:32 PM
