How much hp from 305 torquer heads
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
please tell me about how much h.p. gains can be had from the 305 torquer heads with high flow exhaust such as tes or good cat back system. Tech at Jegs says 30to 35 horses. please speculate or affirm.
Camaro Performers Magazine did a before and after comparison, with a 305 TPI, using World Heads and stock TPI heads. The before numbers were 215hp and 274lb-ft. With the World heads 266hp and 337 lb-ft. So a 51hp and 63lb-ft bolt on increase over stock.
I don't know if the increases would be the same on a TBI because of the peanut cam. But they are a 51hp increase over TPI heads, so they must be WAY better than TBI heads.
I have the article and I think all they did was convert the 85 TPI to a roller cam. In the test with the stock heads the engine made 215hp and 274 lb-ft which almost exactly what the stock version made. So the roller cam they put in the engine had to come very close to the stock one, if not exactly. Both heads were tested with the same cam because they stated that they were “tested under identical conditions”.
But with the LO3 cam don't think you will see the kind of gains they did. iroc22 I will agree with you though, I also think they will be worth around 30hp increase on a stock LO3.
I've heard that you can run 2.02/1.6 valves on the World's
because they have a special design angle to compensate for the
305's small bore.
So who's gonna be the brave soul to try this??
I'm gonna call World first b4 I try anything.
305's small bore.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I believe you are thinking of the Trick Flow Twisted Wedges, not the World Torquers. I could be wrong however...
OMG im about to lose my mind if i see any more posts about whether imaginary cars with imaginary mods can beat other imaginary cars
WELL WHAT IF I BOLTED ON A ROCKET TO THE ROOF OF MY CAR WILL I BE ABLE TO BEAT MY FRIEND JOE BLOW!?
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
depends what you use to mount it to the car
Originally posted by Tas
You're not wrong. In any case, you can run 2.02 valves on the 305 with a .450" or less cam safely as stated by edelbrock.
Yes JR305, they must have used a very similar cam to a stock one, only in a roller version.
i was thinking probably 64cc vortec heads since they are cheap and i hear they perform well
oh yeah in that 325hp 305 buildup they used the vortecs and it made i think 28 more hp than the torquers did....this was a non roller car to...think more than 325 hp could be made on a roller motor?
easily, teh lower resistance of a roller motor over a flat tappet means it will make a little more power withthe same cam specs. with "small" cams liek we are using it is only a little, 5-10 at most, but it is still more.
later
tim
later
tim
I think that TBI can at least make the power of a carb (big argument on the Tech/General Engine board ). I hope to run some strong times this summer to prove it.
IMO the people that are switching to carb are happier because they have more experience with it. Learning to burn proms is not easy, I am in the process right now. I have almost no experience with carbs and have to deal with emissions laws so I will be using TBI for the long run.
see since im only 17 ive never had to deal with carbs or chip burning so im right inbetween....im thinking about staying TBI because it will be cheaper but ill have to start burning chips or something i guess or the TBI will never work very well...but isnt the ECM different in a 88 since it was the first year? i heard you cant burn chips for my ECM....if thats true im definetly going carb
The reason carb is so popular isnt because it can make more power (it makes less torque in every case) but because it's easier to tune for more power.
Car: 91 RS
ambainb
04-25-2016 09:21 PM
