Stock rear sway bar w/Ford 9"
Hopefully somebody out there has some advice for me on a rear sway bar question,
I have a 1988 Iroc 350, w/ TPIS miniram & TPSI ZZ9 cam, Jet Hot ceramic coated Edelbrock headers, ported AFR190 heads, Accel 300+ ignition, 52mm throttle body, TPSI Magnum V prom, 1996 T56 six speed, Currie built Ford 9" rear end with 4:11 gears, I'll stop there.....
Anyway my question concerns the stock rear sway bar.
Is there any way to install the stock rear sway bar with the Ford 9"?
I have not been able to find any info on this.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I ran into the same problem as you. I haven't got it yet but Steve Spohn has a kit to install the swaybar on a 9" rearend. You still have to buy the bushings though for the swaybar as they are not included with the kit.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yup, it can be done. Get the kit from Steve Spohn and then a set of energy suspension bushings (others may work, not sure). You'll have to drill the hole bigger in the C-shell but it will work.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
