most worthwile suspension mod?
...to reduce 60 foot times. At the track about the best 60 foot I got was in the low 2.3s. Im running decent z rated tires with stock suspension. I'll be installing subframe connectors shortly. Im running KYB shocks in the back, and I just replaced all of the bushings back there(after the fact). 130k on this suspension. Any ideas?
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
for the short game, id suggest Nitto's before any real suspension mods if you looking for best game from one MOD. Otherwise LCA's
Car: 1986 Z28
Engine: 355
Transmission: th400
Adjustable Torque arm
That would be the first Mod I would recomend. combination of that, and Subframe connector's it's a whole different car.
I'd recomend Steve Spohn's Adjustable torque arm. It works very well. After driving mine with it... Both off the track and at the track, I think every thirdgen should have one it is that good in my opinon
After those two.. i'd got with LCA's. then DR's/cheaters.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
those are both great ideas, but for cheap, and alot of diffrence, get a pair of LCA relocation brackets, they will make a HUGE diffrence and wont hurt the wallet too bad.
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
how do the relocation brackets work? I'm looking into some suspension mods myself and definitely want the most bang-for-the-buck
TP
TP
Car: 1990 Camaro RS
they work by lowering the rear of the LCA, (axle side) , this helps transfer the power down , it will elimate most if not all of your wheel hop too :-D
LT1Formula
10-08-2015 08:34 PM
