Anyone use Falken tires?
Car: '87 Z
Engine: 355 in the works
Is anyone running or have ever used Falken tires? How good are they? I'm stuck between Falken FK-ZE502 ZIEX or the Kumho Ecsta Supra 712's. Thanks.
I had the ZE502's. When I bought them they were like $80 a piece. Now they're like $120 a piece. They didn't last very long, less than 15000 miles. They're very soft and if you have the factory 16" rims, you cant rotate them without taking the tire off the rim and flipping it over. I would go with the Kumho's.
I use falken 502's, and for the price are an excellent tire (255/45x17). Mine are mounted on 17's though. I hve no trouble rotating front to back because my rims are all 17x8 with 4.5 inch backspacing ( you can't rotate front to back with 16 inch factory rims anyway, because of the different offsets). They are directional though, so you can't switch sides, just front to back. mine have about 18,000 miles on them and are at about half way used up. They are soft, but that's what makes tires grip. They hook up a LOT better than my winter rims and tires (stupid bigs and littles) that are 295's on the rear. You will not be disappointed.
Car: '87 Z
Also, anyone run with Nitto 450's? I'm leaning towards them now. And with the tread rating, higher numbers are better right?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Falken GRB-II's.Good handling tires, in my opinion (245-45ZR16) and better in rain than any others I've tried.
-Rich-
-Rich-
i have falken 255's rear. looks good and price was reasonable. i used to have 215's rear and difference was noticeable. those are not for drag racing but do the job anyway, maybe?
-P
-P
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Falken ZIEX
Yeah, I'm running 245-50-16 ZIEX's all around on my '91 Camaro. They are a good directional tire with great handling in wet conditions (just like it's dry!). My only complaint would be that they corner louder than maybe a soft Goodyear... but they have lasted longer! Would I buy them again? For their price, you bet ya!
