sway bar bushings?
Old 02-07-2002 | 09:09 PM
rezinn's Avatar
sway bar bushings?
I have an 87 iroc and Im in the market for some new bushings. I've been looking over the energy suspension kits, but none of them include sway bar bushings. I believe I have the 36/24mm bars, but I could only find "Bushing set, sway bar mounts, 36mm, black " at summit for the 36mm. Is this correct? What are some good(relatively cheap) alternatives? Thanks!
Old 02-07-2002 | 09:49 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
well you can purchase the front sway bar mounts from energy but you should get the 36mm from a place called www.guldstrand.com. steve spohn turn me to these guys and they seem to have a pretty resonable price.
Old 02-08-2002 | 03:41 AM
Jza's Avatar
Jza
My theory is that the "kits" aren't worth it because they include bushings for the rear control arms and panhard rod, and a lot of us replace those with aftermarket units that include poly bushings anyway. AFAIK, ES doesn't make 36mm bushings, but someone here mentioned that their 35mms fit. The PN# for the 24mm bushings is 5147.
Ed1LE
09-30-2018 09:14 AM
BrianChevy
Wheels and Tires
10-13-2015 12:33 PM
darwinprice
17
10-11-2015 11:51 PM
loud91rs
10-05-2015 10:05 PM
meeklay812
10-01-2015 03:46 PM
Quick Reply: sway bar bushings?
