Who has Tokico Illumina adj shocks/struts?
Car: 2004 GTO
I have found a package of Tokico Illumina shocks/struts with Tokico 1.25" drop springs for $622 shipped to my door.
How do you like them and are the setting changes noticeable?
Thanks!!
Thanks!!
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
dont know much about them on use with a camaro
from those with rx7 though with heavy spring rates dont like them b/c they are too soft even at there hardest setting and so that can leave the spring to bounce around a little bit
though I guess if this is to be a road only car then it woudl work
a common one that I see ppl get over there is a kyb AGX
I know when I get my susp done this summer I am going with some ground controll coil overs with 375 from and 225 rear with the kyb agx to keep everything under controll.
which the car only tips the scales at 2700 or so
might be a little different for you
but if nothing else bippity bump you are back at the top
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Formul* - talk with [www.ground-control.com]Ground Control[/url], but it sounds like a good deal for all four springs, rear adj shocks and adj front struts. I went with a 175 rear spring and when I do the front, I may go with about 650. But I'll talk to them first.
They have a vast amount of knowledge on the F-body in competition.
1992rs/ss
05-19-2020 07:02 PM
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
