would l have a problem with 15X10's?
I got an 87 SC and l aim to bolt on some 15X10 wheels, unless l could fit a 10 inch slick on an 8 inch wheel..... but would l have any clearance problems bolting on 15X10's in the back?
thanks a lot, guys
thanks a lot, guys
Most people that run 15x10s are using a 5.5" backspacing as far as I know. If you a concerned about cutting it too close, you should have no problem fitting a 10" tire on an 8" rim. I know guys that run a 28x12.50 tire on an 8.5" rim so you should be ok.
Don
Don
