Bolt in Weight jack components
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I'm looking for an afordable way for me to purchase a bolt in weight jack system for my 91 Firebird. I would love to be able to lay down $500 for a ground control weight jack system but unfortunately that's not realistic. Are there any companies that sell the component pieces where I could peice together a bolt in weight jack system?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Bolt in Weight jack components
^what he said
You can buy the pieces and weld up a set yourself. If you want to pull the k member you can weld the plates right to the k member and put Te bolts up through the frame into the engine bay.
Engine: 5.7 HSR
I am not a welder but we do have a machine shop here at work and I try my best to stay on good terms with the guys in the machine shop. So I've looked on both of those websites before and there are a lot of choices and to be honest I'm not sure what I can use and what I can't. Any advice on what I can use would be helpful.
86firebird305NJ
01-01-2017 11:30 PM
edpontiac91
05-18-2016 09:43 AM
