Detroit Speed Front Weight Jacks
Car: 1987 Trans Am
Anybody taken a look at these? What makes them different than the swivel style weight jacks you can get at speedway?
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Detroit Speed Front Weight Jacks
It's a bottom up, rather than top down solution. Both are swivel.
Speedway is top down - weld in plate in spring cup (k-member), and turn bolt from the top. Much cheaper, much more work, not reversible (unless you buy another k-member).
DSE is bottom up - plate fits in their a-arms, and you turn the bolt from below the a-arm. No cutting or welding means it is reversible. BUT, you have to have their a-arms, too. Expensive, but if you ever sell the car, you could replace with stock a-arms, then sell the DSE parts to gain back some expense.
1Aauto
Sponsored Vendors
10-05-2017 02:50 PM
1Aauto
Sponsored Vendors
04-12-2016 01:48 PM
