BEWARE moog idler arms, and other generic brands - they are incorrect for these cars!
#201
Re: BEWARE moog idler arms, and other generic brands - they are incorrect for these c
That's possible too... mis-boxed, mis-labelled, counter d00d looked it up wrong, whatever. But, NOT ... straight arm vs "drop" arm, in and of itself.
#202
Car: 1985 camaro z28
Engine: 5.0l LQ4
Axle/Gears: 383
Just installed this idler arm "Falcon Steering Systems K6249" and the geometry is spot on nice and straight in the car.
Falcon Steering K6249
#203
Hi, 3rdGenGuy here.
A few of my subscribers have pointed out that the newer AC Delco idler arms are actually the incorrect geometry. The newer AC Delco idlers match whatever idler arm angle MOOG has been incorrectly making for a while.
I assume it's to fit a wider range of cars.
I ordered a AC Delco: 45C1065 from Amazon.
Thankfully it matches my old AC Delco idler arm. It also matches my Pitman arm angle as well.
So I'm not sure how many bad AC Delco Idler arms are out in circulation, but make sure to check your before installing.
I painted my steering links, so ignore the black paint job.
The following 2 users liked this post by McLovin1181:
lonesomeloser (01-05-2022), NoEmissions84TA (01-02-2022)
#204
Well damn, I thought I read and got the right one (Ac Delco) and It appeared correct at a quick glance but I didn't think to study it. I just installed all new suspension today. The dang new Moog inner and outer tie rods are too long though. I guess I will have to cut them.
#205
Just ordered the McQuay Norris FA1399 from RockAuto and it came boxed in some random brand name box with part # FA1399 written on the box, but thankfully it was the right one!
The drop was 1.5 inches (not the wrong 2 inches like the Moog one) and it had that thick casting line along the edges which usually indicates the right part most of the time.
I think pretty much any idler arm with part # FA1399 should be correct.
Anyways just make sure you follow the center link height setting instructions before tightening up the bolts, I couldn't get my center link high enough like @whitedevilTA with the Moog part because it had too much drop.
On my car, in order to have the center link level I pretty much needed to almost max out the height adjustment even with the FA1399 idler arm to properly level the center link with the front crossmember, even then I barely had any more adjustment left upwards.
I used an app on my phone to act as a digital level and a flat piece of solid steel I had laying around to compare the angle of the center link to the angle of the front crossmember to the closest 1 degree.
This ended up fixing the terrible steering I had at higher speeds.
All good now thanks to this thread, finally!
#206
Sorry to bring up an old thread, but I just replaced some suspension components on my car, including the idler arm, and I can say this:
THE AC DELCO IDLER AND THE MOOG ARE THE SAME.
I had a Moog arm sitting on a shelf in my shop for years, and because of this thread, I didn't use it and bought a Delco piece from Rock Auto a few days ago.
It was the same part, down to the casting number on the arm (6717-C WN2).
Same shape, same parts kit (why did they only come with one lock-nut when two are required?), etc.
I'm not calling the first poster a liar or anything, but I am saying that now Delco seems to be substituting the part.
Agreed in 2024, just did the same complete Moog (with Moog Idler Arm K6249) steering linkage replacement on all my original GM parts. Mine is an all original 1984 Z28 (48k miles), which was still factory parts before I did the work.
I leveled the centerlink (relay rod) to 1 mm. without any issues.
#207
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
#208
Mine was pretty old too and came in a similar random box.
It was some wholesale closeout item for like $5 on RockAuto.
Do you have any pictures of the idler arm?
#209
Car: 87 GTA
Engine: 5.7 TPI
#210
That looks like the one I got.
Same thick casting line down the middle, same rubber dust seal.
The drop from the hole that the grease fitting screws in to and the bottom part that connects to the center link should also be around 1.5 inches.
I gave mine a quick sand and a touch of black spray paint before installing the supplied grease fitting / zerk.
80schild (08-22-2024)
#211
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
remember the mount on body is slotted for adjustment up or down. even with 600+ BBC's this drag link/center link. is almost 2 times the diameter of the stock GM unit.. was thinking of machining 1/4" off the top if I needed the room.or 1/4" plates on the motor mounts. but in the end everything dropped right in. no mods needed. and 1/4" space from center link. and 1/2" on ea side of pan from lock to lock. this pan is way to fat. for my needs. but was the only Aluminum pan on the market that would fit the stoke and rods of this 615BBC. bolt in unit.
