Sway Bar Bushings link tightness??
Car: 87 Trans am, 67 Firebird, 78 Trans
Engine: 355 carbed
Does anyone know how tight to make the front sway bar link bushings... Is there a certain amount you have to tighten them or is it just trial and error... Can you over tighten them, or under tighten them?
Re: Sway Bat Bushings tightness??
The bushings are held to the frame by 2 bolts through the brackets.
Like ALL hardware, their torque goes with the hardware size. (if the engineers thought more or less clamping force was needed, they'd have used larger or smaller hardware)
Given the size that the hardware is (10mm std thread), the torque should be in the 40-45 ft-lb range.
Car: 1983 Z28
Engine: 385 Fastburn
If you don't have a torque wrench, then just get them good and tight. Drive it a couple times, check to make sure they haven't loosened, and call it a day.
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
