popping sound
popping sound
hi i have a 91 camaro 5.0 tbi that im having a issue with, whenever i go over bumps well not always but 7 out of ten times it pops. it also does this when i enter or leave drive ways or i make sharp turns. im fairly new to the suspension in this car but the integra i had before it was the cv joints that would create that sound. any help or tips would be great thank you
Car: '86 iroc
Engine: 305 tpi
Axle/Gears: 2.73? whatever is stock
Re: popping sound
Check your struts. Also check your ball joints. If they start getting bad they can catch and make a popping noise. In my experience bad ball joints also cause the car to wander on the road
Car: 1986 IROC-Z
Engine: LS2
Re: popping sound
I had a popping noise when I was turning. Sounded like it was coming from the driver's/left side of the car. The noise was coming from the steering gearbox. Sounds to me like it's time for the rack and pinion conversion!
