Front Spring Insulator
Do front spring insulators have any influence on comfort?
There are several types, stock soft one or hard poly one.
I want to go for a softer one if they make any difference.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Front Spring Insulator
The stock ones are jus for noise insulation. You can take them out and probanly wont notoce anything different
Car: '89 GTA 350 hardtop
how did you got around this dilema? what else did you changed on the suspension?
I went thru some major updates for the front and rear and decided to go with the moog stock (I think) replacement. I doubt any dampening happens thru the compressed thickness of this insulator. some ppl wrap the last coil in electrical tape.
no insulator may transmit some noise, I doubt u'll notice any comfort difference
also, stock spring had a round section at the end where it goes onto the insulator into the k member cup, my prokits were ground flat. I think the insulator may help conform these two shapes one agtainst the other (not that it can really go anywhere with or w/o a sure footing)
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I have ground control weight jacks and they say not to use an isolator. The weight jacks wouldn't work with an isolator anyway. I can vouch that it's not as bad as you might think without isolators. but its hard for me to tell what made the difference since i upgraded everything at once.
If i had used just regular springs like eibach, moog, or whatever i would use an isolator but i would probably have done the hose slid over the end coil, but OEM rubber would be good too. I can't see any reason to use the harder poly in this application.
ambainb
04-25-2016 09:21 PM
TA8487
08-11-2015 09:02 PM
