OEM 700r4 trans mount HELP !!
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
I had 3 of the 4 nuts come loose inside the trans / chassis fraame when I reinstalled my transmission. Now I only have one bolt tightened up and three bolts on but loose and spinning.
Has this happened to anyone ?
If so, what was your fix ?
Received 1,847 Likes
Re: OEM 700r4 trans mount HELP !!
Yes it happens all the time. Quite routine.
Best way to fix it, is to pop the front seats out, peel back the carpet, take about a 1" hole saw to the floor right above them, get that STOOOOPID chinesium crap out of there, and put a regular flange or captive-washer nut in there instead, maybe even with a nice thick extra back-up washer to keep from tearing the holes out any worse than they already are. You can get suitable nuts at about any parts store. Then put plastic hole plugs in the holes.
Engine: 5.0 TPI
I'm NOT pull the seats when I have to remove the trans cross member !!
but what holds it in place ?
Takes less time than jacking the car up, let alone crawling under it. 3 minutes TOPS, if you're slow like me, and if you stop for another cold one in between every nut, besides. I'm not even sure how you could make it take that long, I'm just giving it the benefit of the doubt. Probably more like 90 seconds.
Engine: 4++,350 & 305 CIs
If I remember correctly, the part that strips or comes unwelded is just a piece of spotwelded inplace flatstock with 3 holes in it that are threaded with the Xmember bolts that GM slams into them during assembly.
Yes, TX and Fueled.
I'm for sure my 89 has has a long flat plate in it intead of those thick circular washer like blanks..
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
NBrehm
08-05-2015 07:57 PM
