4th gen parts to 3rd gen
Car: 1985 TA
Engine: 350 Carb
I have a 1998 firebird that i want to swap the rearend into my 1985 TA. My question is:
1. I have read on here that the 4th gen wheels will then bolt up to the 4th gen rear in my 3rd gen with no problem, is there a parts i can replace on the front end to make the 4th gen wheels fit on the 3rd gen car? or do i just need to buy 2 spacers? Thanks
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 4th gen parts to 3rd gen
Front needs spacers, only other way is custgom brakes and hubs, and that's going to be a mess and cost a fortune.
Car: 1985 TA
Engine: 350 Carb
Both good ideas. Im looking to use as much as i can to improve or just make a little newer. Thanks.
Car: 1985 TA
Engine: 350 Carb
Anybody know where the best place to buy wheel spacers is? And is 2" 5x4.75 to 5x4.75 the right size. Thanks again
Car: 88 firebird convertible
Engine: 305 tbi v8
so the forth gen rear end doesnt need spacers if youre running third gen rims? i thought the rear end was longer on the forth gen. am i wrong?? hope i am lol
Car: 91 Camaro RS
Engine: LH6 5.3
Axle/Gears: 3.43 LSD
If you look at my rear wheels, they sit flush. I have a 95 Camaro Z rear end. The front wheels are sitting in a lot and rub. So that is what your rear wheels will look like. I do want to know more about the spacers. The patern that you listed was the right size, but thickness can vary depending on wheels.
Car: 91 Camaro RS
Engine: LH6 5.3
Also, i have two full coils cut off my front coil springs, so it sits a lot lower then stock. Gonna be raising it here soon.
