Sway Bar bushings that fit factory brackets...
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I bought my poly sway bar bushings from Guldstrand many moons ago - they fit the factory brackets perfectly, but they aren't being made anymore.
Does anyone know of poly sway bar bushings that fit the factory front and rear brackets (I know Energy Suspension sells the bushings that match their new brackets)?
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Sway Bar bushings that fit factory brackets...
Sorry, no answer for that- but Guldstrand... had that car a while, eh?
I'm second owner of my '83. Got it in Dec '86. Still have Rancho trailing arms. Put a Herb Adams rear sway bar on a few years ago... not a very politically correct item at 1 1/8". I love it.
Good luck & enjoy your '84.
I spoke with Guldstrand a few weeks ago and they don't stock or make them anymore.
Wondering if there are any other sources...
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Energy suspension makes them up to 34mm last time I checked. TDS has them, and they have 36, but iirc the ones I got were 34's that were opened up to 36.
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
Just put Moog thermoplastic in. K6457 for the front 34mm bar unsure on rear. Very satisfied, no squeaking and a perfect fit. Seem comparable to poly, dig the blue color
Car: 1987 IROC
Axle/Gears: 2.73 Now 3.42
I ordered mine for my 87 through PST(Performance Suspension Technology). I was VERY happy with the fit and the results..
http://www.p-s-t.com/
Also used several of their products on mine with same results.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I was just on the TDS website and the only two size options in the drop down menu for the front were 30mm and 34mm...
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
I found these on the NAPA website. Not poly bushings, but they do fit 3rd gen sway bar brackets.
http://www.napaonline.com/Catalog/Ca...176_0131001553
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
