Anyone heard fo LoTek Springs?
Found these on ebay. Anyone heard of them before? I currently run dropzones but I'm dropping a V8 in so I need new springs.
http://www.ebay.com/itm/4-New-LoTek-...item53f0ebb01e
Re: Anyone heard fo LoTek Springs?
For starters those front springs look relatively thin. My front springs are twice as thick as my rears. In comparison to the fronts, those look like the thickness of the stock spring I pulled from my RS. I would stick with drop zone or a set of Moogs. Many members have good luck with cut moogs, including myself.
the pic is not even correct front springs do not have a pigtail ends, they are the same diameter all the way. They look like 4th gen springs in the pic. 4th gens have coil on strut arrangement, as such the spring rate is closer to the wheel rate and they need less stuiff springs
Car: 1988camaro
Engine: 355
Transmission: th400
im looking at some too i has a sport coupe that was a v6 now a v8 and alot of extra weight removed, and mine sits nose high 90% unless im on a grade with front facing down hill then its sits low in front i figure has to be springs
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
my general rule is to not use parts from companies that don't know how to spell..
