Fastening Bolts for K-member
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Fastening Bolts for K-member
What year is the car?
Here is the information for 82-90. 91-92 had different part list from what I can tell with 3 different bolt lengths listed (45mm, 115mm, and 89mm lengths).
You basically have 2 options:
Hardware store or GM Dealership.
It should be a Metric 12mm Flange bolt. It's listed as being 1.75 pitch with 115 mm long.
That's right off the GM Parts CD for Firebirds. I didn't pull the one for Camaros because it should be the same and I couldn't find my copy of it. Listed as Item 59 on the diagram it has GM Part Number 14047913. Which looks like it was replaced 01-Feb-2009 with Part Number 22603376. That new Part Number is showing up as "M12X1.75X108". So it's 7mm shorter in length. I'd say by the looks of it around $4.25 list price each at the Dealership. Check your local one though.
Car: check
Engine: check
Transmission: check
I can't help with the bolt sizes, but this thread has a picture of where they go along with the torque spec:
https://www.thirdgen.org/forums/susp...our-front.html
As fireturd350 posted there are 6 total, 3 per side.
RBob.
RBob.
Bohemian
08-15-2017 06:11 PM
Saxondale
Exterior Parts Wanted
09-07-2015 07:11 PM
UltRoadWarrior9
09-02-2015 09:24 PM
