Rear Shock Torque
Old 09-28-2012 | 12:28 AM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Rear Shock Torque
Searched the web, the forum, and my service manual without any results. What should be the torque of the nut on the opposite side of the axle connection? Circled on the pic. Thanks.
Old 09-28-2012 | 12:31 AM
87350IROC's Avatar
Car: 87' IROC
Re: Rear Shock Torque
That should be part of the same stack up at number three in the picture. As indicated, it should be 70 ft lbs. Maybe I don't understand what you are asking.
Old 09-28-2012 | 12:34 AM
antares57's Avatar
It's the nut that holds the shock to the support, but it doesn't appear to able to sustain 70 ft lbs because it's smaller. Better pic
Old 09-28-2012 | 06:30 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There is no torque spec for that because the OE shock had that part of the mount permanently swedged to the bushing.
On that aftermarket (looks like a Delco) shock you are working on, just tighten it until it bottoms out on the sleeve, then just tighten it real nice and tight. You won't strip it unless you're being reckless.
Old 09-28-2012 | 06:47 AM
antares57's Avatar
Thanks! Appreciate the response.
customblackbird
08-15-2021 10:16 PM
LT1Formula
11-16-2015 01:13 PM
sweet_87_iroc
09-25-2015 10:01 PM
kevyb1973
08-24-2015 04:11 PM
Quick Reply: Rear Shock Torque
