cricket sound/squeak from rear end
Car: 1984 Z28
Engine: Vortec 350, hotcam
Every time I go over a bump, turn, or the car leans to one side there is a squeaking sound coming from the back end. The best sound I can describe it as is a cricket. I'm thinking the shocks are bad? I just can't get the sound to happen by bouncing the car up an down.
1 Post
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: cricket sound/squeak from rear end
I had that happen once on my 02. Turns out the weld on one of the exhaust hangers was cracking causing a 'chirp' sound.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Mine did that due to a loose upper shock bushing.
It made a chirping sound over certain bumps.
Tightening the upper shock nut a few turns made it go away.
Car: 1984 Z28
I do have a bad exhaust hanger because it shakes and one side sags down. Ill try tightening the nut too
Car: 1984 Z28
Are the bolts on the upper shock bushing supposed to tighten all the way down? Mine just turn and turn and don't tighten much at all
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
You have to hold the shock shaft from turning.
Typically you tighten the nut until the bushing swells to approximately the same diameter as the washers.
Engine: 4++,350 & 305 CIs
Could be a Ujoint, (bad bushing, loose hardware, control arms panhard bar), broken swaybar endlinks/mounts,sparetire parts loose or rattling, loose heat shield or exhaust hanger.
Many things it could be. You have to get under the car and start bangn around a bit.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
