How hard is it to change front top strut mounts?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: How hard is it to change front top strut mounts?
the spring isn't on the strut, so i wouldn't think you'd need a compressor other than a floor jack under the balljoint to take the stress off the balljoint..
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Takes 10 minutes, literally. Jack up the car, place jack under A-arm. Remove top strut nut. Compress strut and push the rod aside. Remove the 3 nuts for strut mount. Install is reverse of removal. Of course you will need to get an alignment afterwards though.
you can put the car on jack stands at the frame. You need a hand jack under the front control arm to support the spring and tension. The strut can be compressed with your hands and the strut mount can be safely removed as long as the control arm is supported
Terrell351
06-13-2021 01:13 PM
Zachattack0925
08-12-2015 09:52 PM
