Idler arm pitman arm lenth?
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
I working on my steering and I notice the drag link looks slightly not in proportion. It seems where the right tie rod mounts is slighty back compaired to the left side. So I look at the pitman arm compaired to the idler arm and mine are not equel lenth. The pitman is 6.5 inchs and the idler is 6.25 so it seems GM altered the drag link to make it run square with the crossmember. Is my car weird or has anyone else noticed this.
Re: Idler arm pitman arm lenth?
Well I will have to crawl under my car to answer this one, and I am an old man. Maybe someone will post the answer before I check my car.
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Sounds strange to me but i have never investigated that issue. I know that there is an alignment procedure for the center(drag)link. It involves adjusting the height from right to left. These heights must be equal and are adjusted by moving the idler arm up or down using the slotted holes in the idler arm. Not sure about fore and aft alignment of the center link.
no green
01-09-2016 09:22 PM
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
