S-10 MANUAL STEERING SWAP QUESTION?
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
I performed swap and now steering wheel is completly off centered...Is this normal? I centered S-10 (it was 7 turns lock to lock) box before the install. I searched many manual steering posts and did not see anything. Not sure if I have done something incorectly.
Frank
Frank
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
Re: S-10 MANUAL STEERING SWAP QUESTION?
if i remember correctly the pitman arm can only go a few different ways but the rag joint can go anyway. if thats correct just straighten the tires. disconnect the rag joint, center your wheel and hook it back up.i just got rid of mine. but i believe that is how it was
Car: 1990 IROC-Z
Engine: 355/AFR 210
I beilive the rag joint and shaft coming out of manual box have flat spot so that also only goes on one way.
Car: 1990 IROC-Z
Engine: 355/AFR 210
I can't believe no one has had any issue with steering wheel alignment after converting from power to manual steering. Thanks for any input.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I just did mine a few weeks ago, the steering shaft only goes onto the box input shaft one way, it's got a flat spot in it. I remember that being a pain to line up.
The pittman arm could go on wrong but it would be like 90 degrees off, if i remember right the splines wouldn't let it go anywhere in between that.
I could probably snap pics if you need some.
Car: 1990 IROC-Z
Engine: 355/AFR 210
[quote=DeathStarr89;5288656]I just did mine a few weeks ago, the steering shaft only goes onto the box input shaft one way, it's got a flat spot in it. I remember that being a pain to line up.
So after installing manual box you had know issue with steering wheel being off center? My box is 7 turns lock to lock and when centered pitman arm seem to look strait. My issue is when sliding steering shaft onto input shaft on box steering wheel is completly off center by almost 90 degrees. I can adjust pitman arm but then box will not be centered.
Engine: 450HP 355
Transmission: TH350
Nope, mine's perfect.
I'll get you a pic of the steering shaft VS the input shaft to the box, if the orientation of the retainer bolt is the same between them then there must be an issue with your pittman arm.
Engine: 450HP 355
Transmission: TH350
Yah, that almost sounds like the cause..
Here is mine, wheels, steering wheel and pittman arm are all straight. You can see the retainer bolt on the steering shaft is at a little bit of an angle.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
There are slight variances in the pitman arms from manufacturers, and years etc. It is very normal, infact its highly reccomended to have an alignment done after any front end work. It is amazing how such a small difference in parts can throw off the steering wheel. It really doesn't take much.
1992 Trans Am
05-10-2023 08:19 PM
backtothe80s
09-05-2015 01:39 AM
