Strut mount bolts torque specs
Old 05-19-2012 | 10:27 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
hey guys
My Haynes manual says "190" for the torque specs for the "strut to knuckle" torque specs.
I can't imagine this being foot pounds.
Anybody know the foot pounds for the two mounting bolts for each strut?
Old 05-19-2012 | 11:42 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: Strut mount bolts torque specs
Dang I guess it is 190 ft lbs. my torque wrench doesn't even go that high.
Old 05-19-2012 | 12:54 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
One manual had 155 ft-lbs, which is easy enough for me to torque by placing my 155 lbs on the end of a wrench parallel to the ground 1 foot away from the nut to be tightened. 1 foot x 155lb = 155 ft-lbs.
If I wanted to go to 190 ft-lbs I would step on the wrench 1.23 feet from the nut (155lb x 1.23 ft = 190 ft-lbs). The wrench would have to be normal to the direction of the gravitational force otherwise you'll have to cypher with sin/cos or just use my favorite, the cross product.
Old 05-19-2012 | 01:33 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I set the wrench on the highest setting then torqued until I could torque no more. I am guessing it was set at 170 ft lbs, since my wrench's markings stop at 150, and you can turn the handle a bit past that, which is what I did.
I never did get it to "click" but I know the bolts are now torqued to at least 160 ft lbs.
I mean....they aint going anywhere...that's for sure
Old 05-19-2012 | 03:38 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
I've seen 203 ft lbs.....
Old 05-19-2012 | 04:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The later years the bolts are torque-to-yield and are to be replaced after being removed. Example for a '92 is: torque to 125 ft/lb, torque an additional 120*, final torque must exceed 148 ft/lb. This spec is turning the nut while the bolt is being held stationary.
RBob.
Old 05-22-2012 | 09:51 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I used the old bolts and torqued them well past 160 foot pounds
Old 05-23-2012 | 12:45 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Did u remove the strut mount with out removing the front coil springs? If so how is the easiest way to replace these? I have founders perf strut mounts an i havent gotten a chance to replace them
Old 05-23-2012 | 05:01 PM
naf's Avatar
naf
You can remove and replace the strut mount without even jacking the vehicle up. Leave the vehicle resting on the suspension and unbolt the strut bolt and three mounting bolts. All you have to compress on re-install is the strut.
Frozer!!!
01-19-2024 05:55 PM
ASE doc
Alternative Port EFI Intakes
08-25-2015 10:14 AM
Thirdgen89GTA
08-20-2015 04:11 PM
Elliswon
08-10-2015 01:33 PM
