help identifying front suspension modification
Car: 89 T/A
Engine: 5.7
this is probably gonna sound a but newbish, but my I need help figuring out my front suspension, its got a stupid lowering kit on the front a good 2-3 inches(stock on the back) its the way I got it, and I need to fix my ride height, my mechanic says it should be a strut or a coil over conversion, instead im finding the shock mounted inside the wheel well and the coil mounted seperately on the a-arm, any ideas what it could be, time is of the essence here, I was injured during military training so im operating on the schedule of other people who can drive my car for me
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Turbo Buick
Engine: 3.8 V6
Re: help identifying front suspension modification
The coil mounted inboard of the strut is the stock configuration for these cars. It's called Modified Macpherson strut.
Sounds like you just have lowering/cut springs in there
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
What you describe is a factory stock setup. The low ride height as Pablo says could be attributed to a set of lowering springs in the front or cut stock springs. If the rear is factory like you say, its more likely the front springs were cut. a new set of front springs will bring it back up, could do the rears as well since the rears are a cake walk. Any car knowing buddy of yours could help you do the rear springs for free.
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
.21 seconds on google
![](http://www.lukeskaff.com/car/brakes/images/front_suspension_2.gif)
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
And maybe think twice about dealing with that mechanic again.
1992, 69, 84, camaro, fbody, front, gen, identify, identifying, modifications, squeak, suspension, trans, year, z28
