Air-ride+Aftermarket K-member?
Old 05-05-2012 | 02:16 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
If I got a BMR or UMI k member would the ride tech system made specifically for the 3rd gen still fit? both K-members need aftermarket a-arms.... Or should I just go with a coil-over system? I'd also like to know which brand of K-member I should go with. I've heard ppl saying they'd go with UMI if they had the money. I plan on getting a 305 5 speed then swapping the trans for a richmond 6 speed ROD, after doing that swap the engine to a 350, but I wouldnt get a k-member till the swap as I can't find a k-member that fits the 305 and 350????(at least according to summit racing, and it would be easier to just do it then :P) Anyhow. I would greatly appreciate any and all sugestions. I'm not in school, and I live at home for free, so money isn't an issue (within reason, I'd rather not pay more than $1000 before s/h on any one thing). Oh, also should I get a 9" or a 12 bolt? I only plan on making 450ft/lbs of torque... Sorry about all this crammed together into one post D:
Old 05-05-2012 | 07:54 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Air-ride+Aftermarket K-member?
I thought for sure those K members all except original or aftermarket A arms.
Old 05-05-2012 | 08:00 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Umi's will.fit. stock.arms, but the stock arms need a little.grinding. I thought bmr did as well.
Old 05-05-2012 | 11:39 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Would coilovers be a better option than airbags? and on the UMI page it says I can use stock a-arms, but BMR says I need aftermarket ones.
Old 05-05-2012 | 11:45 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
there is no differece between a 305 and a 350 if it fits one the other is exactly the same the diference is inside the motor with bore and stroke
Old 05-05-2012 | 11:50 AM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Thats what I figured, but for some reason they don't show up as the same on Summit racing. :/
Old 05-05-2012 | 04:02 PM
//<86TA>\\'s Avatar
what are you looking to do with the car? coilovers and air suspension are 2 totally different systems for totally different and opposite purposes.
Old 05-05-2012 | 04:44 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I just want the best handling i can get, i may take it to the strip every so often, but its mainly going to be a street machine
matt's 91rs/tt
LSX and LTX Parts
10-08-2015 06:11 AM
Mdenz3
09-17-2015 08:36 AM
tricky1
08-23-2015 01:17 PM
overdriv
08-20-2015 03:52 PM
NBrehm
08-05-2015 07:57 PM
Quick Reply: Air-ride+Aftermarket K-member?
