tire rub when turning and bumps also at 70 very rough
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
i have a 1989 camaro irocz stock tires rims and springs everytime i turn or hit a bump it rubs the fenderwell and is rubbing inside on the frame what is causing this?
next when i get up to about 60-70 mph the whole car starts shakeing dash and all whats causeing this i bought a set of lowering springs but never put them on because of this problem and im not going to now so whats causing these problem? please help
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: tire rub when turning and bumps also at 70 very rough
Have you removed your tires and inspected for any obvious damage or worn out components?
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
your shocks are probably shot, tires could be out of balance, low air pressure in tires.
start simple, when inspecting for issues. with what you described, look at your shocks for leaks and dents, and general condition. jack one front tire up, check for play in the wheel, pull push on the top / bottom then front back, this will tell you the condition of your wheel bearings, and your tie rod ends.
good luck!
good luck!
Car: 92' Camaro RS
Engine: 383 Stroker
Transmission: M5
Check the panhard bar... Bushings may be worn or the bar itself may be cracked. If they're rubbing up front check control arms and or bushings, and struts.
1 Post
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
it wouldnt hurt to have the wheels re-balanced and road force tested either. Hunter machines can road force test.
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
What's easiest way to check shock cause tires have less than 10000 miles on them and I have no clue how old front struts are I know there blue
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
My front clearance inbetween tire and fenderwell is about 1 thinking maybe the strut or spring is bad how do I check these
also my strut towers are cracked and flexing bad so im going to replace them tomorrow would this cause it to sink lower struts look brand new if this doesnt help then im going to go and have it realigned and have the springs replaced
Car: 92 RS
Engine: 94 LT1 383
to check shocks or struts, look for leaking, and dents, as that indicates that they have a very highly likely that they are bad.
next, disconnect one end of the shock, it should extend on its own, and have good resistance when you pull to extend, & push to collapse the shocks, if they go easy they are bad.
or drive your car and have some one video each wheel, if a wheel is bouncing the shock is bad.
next time you are on the road look at a newer cars wheel, you will see that it takes a bump and does not continue to bounce.
then watch for and older car that looks like it has not been cared for, look at its wheels more that likely its wheels bounce continuously meaning bad shocks.
there is also the push test, push down on one corner of the car if the car bounces the shocks are bad.
Engine: 4++,350 & 305 CIs
Also check your idler arm and the rest of your steering linkage for being loose.
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Well if I Press the brakes the nose dives down even if a light brake
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
You can buy them at any parts store Oreillys autozone has them
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Same here. Mine rides like a dream up until about 85mph, then starts to feel "unstable". New struts and mounts, shocks, and tie rod ends, and an alignment. It still does it. My left front wheel pops when I make a hard left turn too, but I haven't figured out where the noise comes from.
1 Post
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Easy way to check struts or shocks while on the car, do a bounce test, bounce the front or rear end with your hands and when u push down and let off-if it bounces up and down twice=bad.
I would check alignment settings, but also if car is lowered alot wouldn't pinion angle be messed up requiring an adjustable torque arm to correct the angle?..
Also, poly tranny mount can cause driveline vibrations at speed..
My car rubs on alot of things at full lock (sway bars, headers, inner fender liner, etc.) I just gave up turning it all the way I know my limits and I lose about 1/4 of a turn on both sides which means a half turn total which yes is annoying when doing a U-turn but that's about it.. It's a camaro... lol
Fronzizzle
03-18-2019 08:29 PM
