Strut mount and A-Arm bolts
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Anyone know of any retail chains where I might can find these bolts locally? I know I can order replacements from Spohn for these but I really need them tonight. Got some threads messed up on my strut mount bolts and my a-arm bolts are really rusty, would rather not reuse them if I can find them.
I have not checked at Lowes yet, but I'm worried about the grade at lowes if they even have the right sizes. I don't think they have anything higher than Grade 8, is Grade 8 strong enough for these parts?
If I do end up having to order them from spohn it's going to cost me more for next day air shipping than the bolts cost
Re: Strut mount and A-Arm bolts
I have found some pretty sturdy, very hard to find bolts at my local Ace Hardware stores. They have by far the best bolt selection of any place I've ever been to that isn't specifically a bolt store (Fastenal, etc). Give them a shot. My local ones have grade 8 and a large variety of Metric 10.9 stuff too.
I am confused though as to why metric bolts are on an "American" car lol Don't get me wrong, I wish America would convert to the metric system, it's so much nicer and easier to work with imo, but I just would've thought an american built car would've had american sized bolts haha.
Thanks, I'll check by Ace. I did stop by a local Fastenal after posting earlier and got some american sized bolts close to the metrics that came off the car. But I'll see if Ace Hardware has something maybe in the exact same size. I'm not sure how much a little play in the A-Arm bolts will matter since the 7/16 bolts I got are just a hair smaller in diameter than the ones that came off the car.
The thing I dont know is whether the strut bolts are super duper special bolts or not. I havent had them off in ages, so I cant remember.
Be careful about the LCA bolts. They have a long shank on them to fit in the bushing and they are of a certain thickness, etc. Kind of like how starter bolts are special because they locate the starter on the block. So those you may not be able to safely source locally. But who knows, I've been shocked at some of the stuff I've found at Ace.
As for the strut bolts, they just look like a hefty sized bolt and nut to me. I think the ones I used from fastenal will be fine there too.
What is really funny though, I didn't play around with my old struts after taking them out the other day. Tonight while reinstalling the new ones I played with the old ones some, I could compress and expand them by hand fairly easily lol. I think they were pretty shot, should make a huge difference in my ride quality and handling hehe. The only thing I'm disappointed about in the new ones is the back shocks are adjustable just like the fronts, but they are adjustable in the same place which is under the carpet in the back .. That is rather annoying have to pull the carpet up every time I want to adjust them.
It did feel good tonight to see the nice shiny stuff together and installed though Just wish I would've had time to paint the A-Arms, maybe I'll pull them back off and do that next week. I'm just on a time crunch to have my car ready by this weekend for an autocross.
If I recall, thirdgen Koni yellows (Mine were on the softest setting in the rear when I got them years ago so I just installed em and never messed with them again) have to be adjusted OFF the car. You have to remove them. Which isnt a super huge deal, they're not hard to get off... but still.
The 4th gen Koni yellows are easier to adjust I believe, but they use a different design of shock. Ours are monotube and theirs are dualtube or something like that, I cant remember, but I did remember everyone implying the thirdgen design was a bit better, even if harder to adjust, if that's any solace to you.
Just wait til you drive around on them. You will be amazed.
Edit: I found this on Frrax, posted by robz71lm7
Shocks
Many people use Koni shocks because they are a quality adjustable shock that doesn’t break the bank. The front 4th gen Koni’s are twin tube as are the rears. However, 3rd gen Koni rear shocks are monotubes and can be used on 4th gens. The adjustment is different however. Koni shocks are available in single adjustables (SA) that adjust rebound damping and double adjustables (DA) that adjust both rebound and compression or “bump.” The downside, besides being twintube, is that Koni’s are costly to revalve and rebuild. Another option is to adapt Koni 30 series circle track shocks to the rear suspension-the same holds true for many universal shocks. Koni offers two models of single adjustable struts for the front on 3rd gens, the Specials (red) and Sports (yellow). The Sports have a heavier valving and are preferred for most racing purposes.
Hrm, well that looks like a real pain in the butt... why would Koni design it that way ....
Anyway, how hard is it to remove these things and adjust them? I've got a mechanic doing the rear end suspension stuff to my car today because I ran out of time to get it done myself after running into so many problems on the front end (mainly with taking things apart). I told him to set the rear shocks about mid way but if I need to adjust them just wondering how much of a headache it's going to be.
Car: 1986 Camaro Z28
Engine: 355 4 bolt 4bbl
Transmission: T-5 manual
Axle/Gears: 3.73 posi.
Car: 87' IROC
From what I understand, you just jack up the rear, pull up carpet, use Koni adjuster tool, and voila? Why un-bolt the botttom of the shock?
For the fronts: Jack up the front, use tool to adjust top of strut? (pretty sure I can do this through J&M strut mounts)
Car: 87' IROC
Which model is the 3rd gen one?
For the fronts all you have to do is use the Koni tool to turn the adjuster. Just open the hood and turn the adjuster. No other tools required. No jacking the car.
For the rears the adjuster is a push button on the shock body. You do not use the Koni tool. You unbolt the bottom of the shock, push the button in with a 1/4" extension and rotate the shock body. You will feel the clicks. You will need to jack up the back of the car to access the button.
If you put in your make, model, year on the Koni site it will give you specific instructions for our stuts/shocks.
http://www.koni-na.com/cat_search.cf...18&submit.y=19
That's alot simpler than I thought for the fronts. Cool.
The rears seem a bit more complex. Where is the push button located on the rear shock? And I assume there is no need to pull up the carpet once it's installed to get the adjustment done?
No.
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
When talking about shocks. The best way to discribe changing the compression damping is to say (Harder) or (Softer) When talking about adjusting the rebound it would be (Faster) or (Slower) It's easier to understand that way.
Car: 87' IROC
The push button is on top of the shock body, next to where the piston comes out of the body. Refer to the instructions in the link I provided. It is easy to tell in the pictures. It should take less than 20mins to adjust both rear shocks including jacking up the car. Its really not that hard.
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
I thought the old style rears had the "compress fully and twist" method of adjustment... I bought mine in about 2002, so they must've changed something.
ambainb
04-25-2016 09:21 PM
Thirdgen89GTA
08-20-2015 03:11 PM
