new end links
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
new end links
looked at em today after months of a "death wobble" and it didn't look good
so i got these at napa
then i had to swap them, only got one side done because of the RAIN (which i hate) and the fact that i broke the spare tire jack and had to go buy a jack
after 25 mins i had the old one out, as you can see any and all bushings were GONE, heres the empty space where it should have been
and the finished product, love the fact i have poly bushings now, hopefully they'll last awhile, also the new links are stainless so they wont rust like the old ones did they were $18.
still gotta do the other side tomorrow and then
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: new end links
that will not cause a "death wobble"
Transmission: 5spd
Re: new end links
wasn't really a death wobble, but a noticeable one when driving on the brick streets around town, and over speed bumps, and a strong pull to the right on the interstate
Re: new end links
that still wont cause any of that, all it will do is make a little noise perhaps.
Received 1,839 Likes
Re: new end links
I've done it to several of my cars really badly over the years
Transmission: 5spd
Re: new end links
its not bad with a jack and some blocks, the way mine were and idk if its right or not because its backwards of the insturctions (the nut on top, and the bolt put up through the bottom) was fairly easy a 13mm wrench on the top placed between the strut and the inner fender will all but hold itself while you use a socket on the bottom part, then take a small mallet and tap it out, the hard part is getting it all back together, again i used a small mallet for tapping the new one back up in and sliding the bushings/washers/sleeve over it and getting them to fit snug, be warned though you will be tightening it down for about 5 mins until its snug
Transmission: 5spd
Re: new end links
got the other side done today, also had the time to switch the old (not really very low miles) l69 over to valvoline max life full synthetic, and a new k&n oil filter (no pics yet of that) but heres the new one
and the old chewed up bushings, things felt like hard plastic when i got em out once again with a little help of the mallet and an electric impact wrench
car runs good now, only complaint is that my alternator belt, and my power steering pump belt squeal (cheap *** duralast belts) but i love how great she runs, and how solid she feels now
Re: new end links
The ones in the above pic are WAY WAY WAY overtightenened...
The rubber should only be SLIGHTLY larger than the washer; maybe 1/16" larger. They shouldn't be mooshed and ballooning out like that.
Basically they're probably ruined.
But now that you've had some practice, and you know how cheeeeeeeeep and eeeeeeeeeeezy they are to change out, and how much of an overall improvement in the car that they make, it's time to go get some Energy Suspension or Prothane ones, and install them properly.
Transmission: 5spd
Re: new end links
they aren't like that anymore, once i got the car back on the ground everything evened out
Transmission: 5spd
Re: new end links
I've gone over (well under) everything pretty closely I've cleaned the underside up a lot and I'll probably be ordering a complete new bushing set from energy suspension this summer
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Re: new end links
No end link bushings: more of a death "jingle".
Wobbles or pulling are more serious and caused elsewhere.
Transmission: 5spd
Re: new end links
it didn't pull much and the wobble could've been something else, i definitely felt movement form the front right side tire in the wheel as i said, and it doesn't pull anymore, just sorta drifted that way if i let go of the wheel for too long before, but new ones are a big improvement
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
db057
08-11-2015 10:11 PM
