A Arm Powder Coat and Bushings
Car: 92 RS
Engine: 3.1 V6
Ok so just got my A Arms back from powder coating.. Great job but the bushing and ball joint press points are also powder coated.. Anybody pressed them in without grinding away the powder coating where the bushing and ball joint cases seat??? Not sure if the powder buildup will prevent them from pressing in or if it will make it way too difficult.. They were blasted before powder coat...
Thanks....
Thanks....
Engine: 4++,350 & 305 CIs
Re: A Arm Powder Coat and Bushings
I always clean the coating off b4 I press in new bushings. Makes it a lot easier.
COTM Editor
I used a drum style shaft mounted sanding wheel on my die grinder and just cut down the bushing are to metal and squirted some black paint in there and pressed in the new bushing and joints. 6 years later you would never know the podwer was ground off in those areas.
Hotrodboba400
12-10-2019 07:07 PM
rudolphschenker
09-04-2015 02:41 AM
arms, ball, body, bushing, bushings, coat, coating, joints, masking, powder, powdercoat, prees, suspension, t5, transmission
