1 7/16 sway bar bushing
Car: 89 trans am gta
Engine: 5.7L tpi
Transmission: 700r4 4 speed
Axle/Gears: borg warner aussie 9-bolt 3.27
would a moog 1 7/16 sway bar bushing work for a 36mm sway bar ??
http://www.ebay.com/itm/MOOG-K6459-S...ht_1262wt_1031
Re: 1 7/16 sway bar bushing
Have the seller give you the outer dimensions of those bushings. I suspect they won't fit the stock GM sway bar bushing brackets. I recall a little over a year ago buying these bushings in an attempt to find a new supplier, since Guldstrand's supplier no longer wanted to make them in anywhere close to a reasonable quantity. The Moog bushings I rec'd did not fit the GM brackets. If the eBay supplier won't or can't supply you with the dimensions of the bushing, then make sure they have a return policy. I solved my supplier problem by buying Energy Suspension 34mm bushings and honing them to 36mm.
I know your original concern was the ID of the bushing. FYI 36mm = 1.417" so if these measure 1.437, they are roughly .020" larger.
Lon
Lon
1 Post
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
I made the mistake in buying these bushings. They don't even come close to fitting in the bracket.
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
darwinprice
17
10-11-2015 11:51 PM
