how much to shorten rear end?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
got a deal on a set of rims that ive been wanting so im set in stone on keeping them. the sit ok, but i want the to sit right in side of the quarter panel. looking to shorten the rear 1"-2" just enough so there no gap between the rear well but room so the wheel can travel. anyone know hoe much itll be?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: how much to shorten rear end?
Probably cheaper to buy rims with the proper backspace.
To shorten the diff, you'll need to buy or find someone with an alignment jig so the housing doesn't warp when the ends are welded back on. You'll then need to buy new axles.
1 Post
Engine: 355
Axle/Gears: 373
buying rims are out the question as my set run over 5k new, 3500 used.. anyone know how much im looking at? new axels is no prob. upgrading gears anyway so might as well beefin it up a lil.
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
hectre13
08-26-2015 08:17 AM
