Rear sway bars
Rear sway bars
What rear bars were available for 3rd gens?
Somehow I assumed that most of the 3rd gens that came from the factory with a performance suspension came with a 23mm rear bar, the 24mm bars were pretty rare and most of the rest came with a 3/4 or 7/8" bar. I never really paid attention to what rear bars I had sitting around, but I always figured that I had one of each common size by now... I don't
I went and measured what I have sitting around and it turns out that out of 6 rear bars all except 1 are 24mm, and the one smaller one is a 21mm which I've never heard of before. The odd thing is that my '83 TA came with a solid 32 front and 24 rear (no wonder I always liked that car better with poly front bushings and rubber rear), my '87 TA has a 36/24 (I'm pretty sure that they're stock based on how stock the car was when I bought it), and my '87 Formula 350 is the oddest with a 21mm rear (and 36 front, this is even weirder since I bought the car from a locally competitive autoxer that bought it new, put the stock wheels/tires in the attic and started racing it from day one, why it would have a 36/21 I don't get).
1 Post
Car: 82z28
Engine: 406
Transmission: th350
Re: Rear sway bars
There may be others but these are the ones I have recorded with possible part numbers.
REAR (24 MM) 10035033
REAR (18 MM) 10021220
REAR (21 MM) 10021221
Re: Rear sway bars
You might find something interesting in the following link:
https://www.thirdgen.org/forums/faq-...-sway-bar.html
JamesC
JamesC
Received 1,862 Likes
Re: Rear sway bars
Yup...
"Performance Suspension" varied quite a bit over the years, and from model to model.
Additionally, just jamming a "bigger" (or whatever) one on there, is no guarantee of "better".
Generally, assuming front & rear springs are well matched (not something you'd want to just "assume" in the case of an old wore-out stock setup), there will also be an "optimum" match of front & rear sway bars. It's pretty easy to get the car too tight (goes straight when you try to turn) or too loose (tries to swap ends and spin out) under some circumstance or other, if the sway bars are too heavy/light on one end or the other.
Never saw a 24 bar on a car from before about 85 myself; not saying it didn't happen, but I am suspicious. Hard to get "features from the future". Most of the 84-back "hi-perf" cars had 21mm bars.
Re: Rear sway bars
JamesC
JamesC
- there's no 21mm rear bar for '87 (what my '87 formula 350 has)
- no 24mm for 83 (what my '83 TA had)
- no 36mm front bar for '87 (what both my '87 Formula and '87 TA have)
I wouldn't be surprised if the previous owner of the '87 Formula swapped parts, but I'd be shocked if either the '83 or '87 TA were messed with. The 83 was _completely_ stock when I got it in, holy crap, 20 years ago, and the '87 was totally stock except for a pink shift **** and sticker on the nose that someone stuck on it.
BTW, all 3 are WS6 cars (so is my 4th gen)
Actually, I have all the suspension parts from a base model late 80's camaro (another car I'm pretty sure never got messed with, bought by a friend's mother new and was totally stock when we messed with it), which looking at that list should have had a 30mm front and 18mm rear, and I don't have either of those sitting around.
I also don't see the 23mm rear bar that everyone keeps talking about.
So based on that list I should have:
2 34mm
1 30mm
1 21mm
1 18mm
that I don't have, just based on the cars I've had.
Re: Rear sway bars
Huh... one thing that that thread does seem to confirm is my suspicion that my favorite setup (32mm solid front) would be the same but lighter with a 34mm hollow (which appears to have been matched up with the same rear bars in that list.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Rear sway bars
From what I understand:
18mm (6 cylinders with rear bar)
21mm (Z28)
23mm (IROC)
24mm (WS6)
I know all these bars exist because I have had all of them and some were mounted on one of my third gens.
In terms of racing rear bars, depending on your style of driving will dictate your rear bar - heavy on the gas typically requires less rear bar. I'm running a 36/18 combo with a 12 bolt. If I drive it normal, front end pushes a lot; drive it hard and the car is very balanced and is controllable under power.
21mm (Z28)
23mm (IROC)
24mm (WS6)
Re: Rear sway bars
82-84 Level II Y99 - 12MM
82-early 84 Level III WS6 - 21MM
late 84 Level WS6 III - 23mm
84 15th Anniversary T/A-early '85 WS6 - 25MM
late 85-up Level III WS6 - 24MM
85 Level II - 23MM
This is what the GM master parts catalog specs out for V8 cars. V6 cars typically ran 2-3MM smaller bars with WS6)
My late production(5th week 8/1984, Van Nuys) '84 T/A with WS6 has the 23mm bar. Confirmed with a digital caliper.
85 Level II - 23MM
Car: 1986 Z28
Engine: ZZ3
Re: Rear sway bars
To add to the mix, my 1986 Z has a factory 34/23 (edit) set up. Confirmed with a digital caliper gauge.
Re: Rear sway bars
85 Level II - 23MM
85 Level II - 23MM
The "GM master parts catalog" you mention: What model years(s) and vehicle lines does it cover. Where did you find it?
Myself and others would be grateful if you could share the GM part numbers to the sway bars quoted in your note, as well as the matching bushings.
Thanks!
Re: Rear sway bars
Re: Rear sway bars
I have what is shown in the eBay auctions although mine is on microfiche instead of paper. Its what the dealer's parts department uses to look up parts. Mine is for '82-92 Firebird, April 1995 edition so some parts may have been discontinued and no longer listed or have superceded part numbers.
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
