ground control weight jacks?
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
i was looking at geting ground control weight jacks for my car but the web site asks for the shock type and i was wondering will they work with stock shocks or do i have to get one of the kinds listed on the site?
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Re: ground control weight jacks?
Although I'd upgrade shocks before doing the weight jacker kit. Not sure I'd trust stock or other low-end shocks (i.e., not Koni or Bilstein) working with a lowered suspension.
Pat
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
They'll work with any shocks. They mount in the same location as the stock springs, so the type of shock doesn't matter.
Pat
Pat
The reason they ask for the shock you are running is that they match the spring rate to the shock & type of driving you do as the springs are custom to each set of weight jacks. Thats why you cant get just the springs from them unless you already have a set of weight jacks.
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Pat
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
They work great with my KYB Gas-A-Just shocks & struts that were on the car when I bought the car in '06. Bought a used set of GCWJ in 09 or 10 & never been happier.
Engine: 355ci
ok thanks for the help
eightsixseven
08-14-2015 03:09 PM
