HOW do i index front coils
Car: 1985 camaro Z28
Engine: 350 pos
Transmission: trbo 350
Axle/Gears: 308
ok so i bought a set of ksport gt lowering springs 1.75 all the way around i still need to install the rears yet but when i instaled the fronts it stayed the same ride hight as stock z28 springs so IDK what i did and i hear talk about indexing them so anyone with helpfull info i will greatly apreciat it and if you can plez send pics and tech info because i am tierd of tearing it apart i just want it done right once thanks :thanks:
Re: HOW do i index front coils
ok so i bought a set of ksport gt lowering springs 1.75 all the way around i still need to install the rears yet but when i instaled the fronts it stayed the same ride hight as stock z28 springs so IDK what i did and i hear talk about indexing them so anyone with helpfull info i will greatly apreciat it and if you can plez send pics and tech info because i am tierd of tearing it apart i just want it done right once thanks ![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
In the following pic the two drain holes can be seen below number 12 (first pic in the link):
https://www.thirdgen.org/forums/susp...ion-101-a.html
JamesC
Engine: 350 pos
Axle/Gears: 308
thank you for the info im assuming that you r talking about the 2 holes that are close toghter in that case all i need to do is slid it back about a 1/2 inch becasue im asssuming that those holes are buy the notch in the a arm where the spring sets hopefully that fixes the problem but for somereason i cant even remeber thier beinging 2 holes but well find out today i gess thank you
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Just make sure one hole is completely covered by the bottom coil that's making contact on the a-arm. Its easy. As far as indexing on the rear springs go there isn't a spec, but i have found that moving the coils around has helped get things level.
![Name: springholes.jpg
Size: 34.8 KB](https://www.thirdgen.org/forums/attachments/suspension-chassis/392255d1501424279-how-do-i-index-springholes.jpg)
Engine: 350 pos
Axle/Gears: 308
thanks everyone for the info all i had to do was twist both back about 1/2 inch got bothe done in about 45 min now on to the rears
![Name: springtab.jpg
Size: 8.7 KB](https://www.thirdgen.org/forums/attachments/suspension-chassis/392230d1501424220-how-do-i-index-springtab.jpg)
here's a pic i found that will make more sense, the suspension unloaded but the perches are not level even with the suspension loaded as i recall.
![Name: hppp_0805_04_zdisc_brakes.jpg
Size: 77.0 KB](https://www.thirdgen.org/forums/attachments/suspension-chassis/392231d1501424220-how-do-i-index-hppp_0805_04_zdisc_brakes.jpg)
Terrell351
06-13-2021 01:13 PM
TA8487
08-11-2015 09:02 PM
