which rear shocks are better for quarter mile and handling?
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
Im debating between gabriel hi jackers part #49203 air adjustable, or the kyb gr2 gas shocks,. Which ones will allow me too hook better and handle the corners?
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: which rear shocks are better for quarter mile and handling?
the air shocks suck they ride like a rock and put a ton of stress on the shock mount. The gr2s are a good all around shock for handling and dragging. For straight dragging though id get some 50/50 drag shocks
ok ty for the info, does anyone know where too find a good set of 50/50 drag shocks cheap?
Car: '89 IROC-Z
Engine: 355
IIRC autozone had lakewoods for $60/pr
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Shocks are a tuning aid. No shock will give you the best of everything. For drag racing, an adjustable shock allows you to change how the suspension reacts to different track conditions. If the suspension is set up properly, you want the shock to extend quickly on the launch then slowly allow the suspension to compress again.
Road race handling needs a different shock setting. A 50/50 shock may work but a 3 way adjustable may be a better choice for tuning ability.
who has the lake woods 60.00 a pair? ive tried searching for them and cant find them
Engine: gone
Transmission: gone
Axle/Gears: gone
He said Autozone. Check Summitracing. streetsideauto. jegs.
Normally you want a 50/50 shock for the rear and a 90/10 for the front if your doing only drag. For everyday its really rough. Id go with some KYB gas a justs in rear or koni's
LT1Formula
11-16-2015 01:13 PM
