Sway Bar Size
Sway Bar Size
Im replacing sway bar bushings on my 91 firebird 5.0 tbi convertible and wanted to see if there is a way I could tell the diamieter of the sway bar other then getting under the car and measuring it. Does RPO's or vin have anyting to determin this?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Sway Bar Size
measure it from the top? seriously, you can do it.
probably a 32mm.
probably a 32mm.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Sway Bar Size
The car is 20 years old. Take nothing for granted & assume that everything is exactly as it was 20 years ago & hasn't changed, like the RPO codes saying whatever.
Physically measure & you can't be wrong that way.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Sway Bar Size
IKEA has free paper measuring tapes that are great for measuring sway bars.
I keep a few in the garage...they come in handy sometimes.
camaro1185
10-26-2015 06:51 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
