Whats the best tire/suspension combo for max traction on the cheap?
Location: Newark,NJ The state where racing on I 78 rules.
I have a 383 motor with 3.73 gears in the rear & I have no traction at all! Whats the best tire/suspension combo for the least amount money? I also need to put my car on a diet of at least 200lbs. What can be removed from the car. The back seat is not needed!
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
3inch
njdaewoo@excite.com
383sb engine
smog pump by-pass
go with the biggest tires possible, get some 15 inch wheels cause tires will be cheaper, most 275/60/15s will run you about $60 a peice, as for the weight, throw out the spare tire, A/C, smog crap, back seat, thats all i can think of right now.
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
87 IROC-z 305 TPI
Damon
09-26-2015 04:29 PM
