Weird Squeaking in Rear Suspension
I have a strange noise coming from my rear suspension. It happens when I go over speed bumps,into driveways,or when cornering. It sounds like a high pitched groan or squeak. It sounds like rubber groaning or something.Is it my bushings ,springs,or is there a part that's loose maybe? The car has over 175,000 miles on it and the suspension isn't very tight. Has this ever happened to anyone before? I need a couple of suggestions.
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Its probably the bushings in the panhard rod and or the LCA's. Either grease them or replace them and the noise will stop.
bjpotter
01-22-2019 12:27 PM
