Who makes the best lca relocation brackets?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Can you please post a link or a number and maybe a price thanks.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Probably Steve Spohns but I made my own.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
No question about it the Global west units are the best. The fit and finish are number one. The only thing bad about them is the price.
Link for Global west
http://www.globalwest.net/camaro93.h...uat%20brackets
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EIBACH spring kit, NITTO'S, N.O.S.
best 60ft 1.84 1/4 12.48 @ 110.81
I second the Global West recommendation wholeheartedly!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can't see what's so special about the Global West ones that makes them almost twice the price of Spohn's.
Car: 86 Z28
I have been e-mailing spohn, but he has not got back to me and It has been weeks now.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i would say spohn or i have BMR RELOCATION BRACETS. I WAS GOING TO BY SPOHN BUT THEN I FOUND SOMEONE SELLING THE BMR BRACKETS FOR LIKE 40 SO I BOUGHT THOSE INSTEAD. THEY ARE WORKING WELL..
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
91 camaro RS
- 305 TBI
Ummm, DUH!..
Yer supposed to WELD the Spohn brackets on.
The only ones I've seen that can just be bolted on, and yet still aren't a safety hazard, are the BMR ones. (they do make a weld-on only set.)
The difference is the bolt-on ones have an "ear" that slips on the rear shock mounts for bracing.
Even with these, I'd only use them in mild-modification applications. If yer sportin' big power, WELD that thing on there...
Just FYI:
This is on the Spohn website, AND on the directions that were in the box my brackets came in...
"Must be welded into place. All Grade 8 hardware is included. Since the brackets must be welded in place, we ship them bare. Welding in LCA Relocation Brackets are the only SAFE and EFFECTIVE way to install them."
Car: 82 camaro SC
Absolutely must be welded for safety. As long as the material is strong enough, the brand doesn't matter.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Kudos to Steve Spohns products
13.3 @ 101.3MPH 95 degrees and 95% humidity w/ no tuning on motor
Sportsman II, Gear drive, Perf. Res. chip, SLP 1 3/4" headers, Edelbrock muffler, Trans-go stage 3, Vigilante 9.5", Functional Ram Air hood, SLP roller cam, 24lb ADS injectors, AFPR, 3.45 gears, Stealth intake, 58mm setup, Spohn suspension, and other goodies...
raven
Custom EFI Intake Setup
raven
<font face="Verdana, Arial" size="2">Well no kidding they have to be welded. But I said "when you install them", meaning you put them into place before you weld them, how do you know if you have them in the right place before you start welding?
</font>
</font>
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
ambainb
04-25-2016 09:21 PM
evilstuie
04-14-2016 08:52 PM
Thirdgen89GTA
08-20-2015 03:11 PM
NBrehm
08-05-2015 07:57 PM
