New Idler Arm still stiff even after lube
I have not yet installed this arm into the car. I installed the grease fitting into the idler arm joint until it was nice and tight, then stopped before it was flush, so I wouldn't strip the thread. Put 4 entire squeezes of the lube gun into it. Lots of grease coming out of the top of the joint. I can rotate the support bar inside the joint, but it is pretty stiff still, takes some force to move it, it's not gliding freely. Is this normal? Should I keep adding more grease until it moves easily?
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Car: 88 IROC
I think that's normal. They get all loose and floppy when they wear.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
no green
01-09-2016 09:22 PM
LT1Formula
10-08-2015 08:34 PM
