Is it better to run 245's all around or 245's front and 255's rear or all 255's??
For handling, street racing, drag racing (at track), and whats the actual difference that the different combinations make on an IROC-Z?? Thanks!!
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
89 RS
STILL Looking For:
I have 265's on the front, and 295's on the rear.. works well.. cornering isnt bad... But then again I havent driven another camaro with a different tyre setup..
Probably be wiser to have smaller width tyre at the front for steering, and larger tyres at the back to get the power to the ground.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by LarsZ28:
Probably be wiser to have smaller width tyre at the front for steering, and larger tyres at the back to get the power to the ground.</font>
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
COTM Editor
Received 1,919 Likes
Car: '89 Firebird
Engine: 7.0L
If you are running a 16x8 rim then you definetly want to use the 245/50-R16 tires for cornering. The width gain of the 255 tire is almost negligable but the change in sidewall height is significant. You will substantially reduce handling ability when using a 255 relative to a 245. However, for drag use you want the extra sidewall that the 255 affords. For top speed you want the 245 becuase there will be less parasitic drag.
For an all round car use the 245 tire. It's closer to optimal on an 8-inch rim then the 255 tire.
The way I understand it is anything over 255 is simply cosmetic on IROC rims. 295's on 8" rims won't provide any more traction... I think, can anyone confirm. I do like the idea of putting 295's on mine actually, even just for show
'86 Iroc ZZ4
Best Run 13.8 @ 100mph
I told you to blow the bloody doors off!
The British Firebird/Camaro Site
'86 Iroc ZZ4
AkDrifted
08-17-2015 07:45 PM
