New Struts / Alignment
Car: / 89 IROC /
I'm getting new struts tomorrow, do our cars need an alignment after replacing the struts? I know some cars you do not have to.
Thanks!
Thanks!
Car: 82 camaro SC
Struts vary slightly by brand and most have a small amount of slack in the bottom bolt holes. Also, if you haven't had it aligned for a while(more than a year or so) it probably needs it anyway. While your at it do a performance alignment to it.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
LT1Formula
10-08-2015 08:34 PM
