Do M/T Sportsman Pros need inner tubes?
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I planned on running some Sportsman pros(26x9.5-16) on my car and was wondering if I would need inner tubes? Also my rims are 16x8 wanted too know if maybe I could run a wider tire or are these just fine?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They are not a tubeless tire. If you run them without tubes, you'll be constantly topping up the tire pressures every week. I don't run tubes in my ET Drags and every week or 2 they go flat.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
I had a set for over a year that didn't lose any air without tubes. Most of the time they sat in the garage though. The tubes just add weight IMO.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
I also have a set of Sportsman Pro's without tubes, which I drive very often, and they have kept their inflation very well over the course of aboiut 6 months. I might have topepd them off once in the 6 months.
On my car they hooked better than drag radials. Neither drag radials or the Sportsman's will hook like slicks, however.
Hope this helps.
RSR
Hope this helps.
RSR
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I'm just looking for some tires that I can use on the street. I do alot of street racing and wanted something better than the Pirellis I have now(they spin real bad). Just trying to decide on the NITTOS OR Sportsman Pros. Thanks
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Paxton SN92
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Paxton SN92
if your gonna run them tires without tubes coat the inside with dawn dishwashing liquid this will help keep em from losing air it may sound weird but we do it with all our drag slicks that dont have tubes
gixxer92
05-18-2017 11:20 AM
no green
01-09-2016 09:22 PM
