Silicone -brake- lube?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Firebird
Engine: 2.8 V6
So, is this the same as silicone dielectric grease (for spark plug wire boots)? To rebuild the m/c, you need some silicone brake lube on the reservoir grommets. The local auto store sells little tiny packets for $0.50 of silicone brake lube; I used a few when I rebuilt the rear calipers. (I needed the stuff for the caliper's slides/mounting bushings and mounting bolts.) I wasn't sure if the stuff was the same as regular 'ol dielectric. I can't remember ever seeing anything marketed as "silicone brake lube".
Thanks in advance!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Thanks in advance!
Car: 1983 Z28
Transmission: WCT5
I may not be totally right here, but I thought the brake lube was for brake fluid compatibility. For use on internal brake parts. I've always heard that you can use lithium grease on any of the "external" parts (like mounting hardware and the floating sliders).
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Clem
Car: 1986 Firebird
Engine: 2.8 V6
No kidding... I didn't know that. Is it maybe because silicone's the best lube for the slides?
The guys on the tech board gave me the answer; the silicone brake lube is the same as dielectric grease. However, it turns out I don't need any; (see my msg about the master cylinder) my m/c rebuild kit didn't come with the reservoir-to-housing grommets.
